CSRP master cylinder, proportioner and distro block question
Old 04-04-2013, 07:03 PM
  #21
120mm
120mm's Avatar
120mm is offline
Old 04-08-2013, 12:52 PM
  #22
crunchyskippy
crunchyskippy's Avatar
120mm - It looks like you bypassed your distribution block for the rear brakes. Any particular reason for this? By doing so, your dash brake warning light will always be on as it will continuously sense an unequal pressure between the front and rear brake circuits.
I know you have had a fun time with the brake lines, but I would reconsider plumbing it correctly (i.e. from rear brake resevoir to distribution block to proportioning valve to rear brakes) for safety's sake.
crunchyskippy is offline
Old 04-08-2013, 08:00 PM
  #23
Starfury
Starfury's Avatar
Agreed.
Starfury is offline
Old 04-12-2013, 10:09 AM
  #24
120mm
120mm's Avatar
I "thought" I was following the instructions. That's why I did it that way. I don't see why I can't do it as you describe, now.
Here is where a simple picture, in the instruction manual would've saved a lot of heart ache. It's not the end of the world, and I really appreciate the critique, which is why I posted the pics. The internetz can be a very, very good thing in cases like this.
120mm is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Luke9222
10-22-2015 11:55 PM
bconboy
09-21-2015 12:52 PM
Mikett
09-12-2015 10:52 PM
09-08-2015 05:21 PM
Quick Reply: CSRP master cylinder, proportioner and distro block question
