What gears should I get for my 68 mustang
Old 05-17-2013, 04:29 PM
wgc68nyc
wgc68nyc's Avatar
As a guy in the same boat with the same setup I wouldnt bother till you do your transmission (exchange for AOD or 5 or 6 speed manual).
With a stock engine unless you go up to high gears you won't notice it that much. With high gears the highway stuff will suck (I do long distance on highways).
What I would and did do is find out the rpm range you like to be on the highway at cruising speed. The use the gear calculators to match that up to the MPH you would like to be going (65 70 75) and then use the AOD or T5 or T6 gearing to back into what rear gear you can get.
Be aware that your other shift points will change so spend some time on this otherwise you could end up in the wrong RPM range or gear other times.
Me personally:
aod c4
First: 2.40:1 1st 2.46
Second: 1.47:1 2nd 1.46
Third: 1.00:1 3rd 1.0
Overdrive: 0.67:1
3.4 in aod 2061 @ 70mph....maybe go a little higher
wgc68nyc is offline
Old 05-20-2013, 10:05 PM
imboden
imboden's Avatar
I did 3:55's with my T5 swap. I'll always wonder what 3:73 would have been, but I'm happy.
imboden is offline
Old 05-22-2013, 08:09 PM
Stangatic
Stangatic's Avatar
Don't do 3.80's! It was the worst mistake I made when I had a c4! It took all the fun and drivability out of the car!
Stangatic is offline
Old 05-23-2013, 05:16 PM
Greg West
Greg West's Avatar
I have ordered the 3.5. Hopefully the assembly will get here in a couple of weeks and I can get it installed. Thanks for all the comments guys.
Greg West is offline
ShaneB26154
35
03-04-2021 04:05 AM
Urambo Tauro
09-07-2015 12:47 PM
jc1
08-29-2015 07:09 PM
daytooday
08-11-2015 09:22 AM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: What gears should I get for my 68 mustang
