Locking Differential for Cougar Rear End
As I had posted earlier, I picked up a 9" rear end out of a 1970 Cougar to install in my 68 fastback. I plan to upgrade to a locking differential and new 3.50 gears when I have the center unit rebuilt.
I noticed when I sorted differential carriers for Ford 9" on the Summit Racing website, there were about 15 choices but if I sorted by Mercury 9" there was on 4 choices. I guess I thought the Ford and Mercury 9" rear end carriers were basically the same. Puzzled why there were so few choices for the Mercury rear end. I just want to be sure that unit I buy will fit my carrier.
Based on the information I found on this forum, decided on the Detroit TrueTrac unit unless someone has a better suggestion.
Thanks!
Thanks!
Location: Detroit; where the weak are killed and eaten.
9" is 9", so far as I'm aware. The choices that show might be what was available for Vehicles that carried that 9". There probably weren't a lot of choices for Mercury, because not many vehicles in the Mercury line carried 9" rear axles for very long, and with very many models.
Wheres 9" was available on a lot of Fords for a lot longer.
Make sure you don't go the cheap rout with the ring and pinion. With a Trac-Lok rear axle, if you buy cheap ones, they can be very chatty and have a lot of noise.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
