none of my exhuast is welded.
I was looking at my exhaust system and realized that none of the pipes appeared to be welded. My dad and i were considering renting a welder and welding all of the exhaust pipes together. We were told that welding is pretty easy to get. All of the pipes are connected, they just need to be welded. Also, what is so hard about installing the headers onto the intermediate pipes. What do you guys think? I have experience in soldering. (joke but true)
RE: none of my exhuast is welded.
By the time you rent a welder and equipment you could most likely have a muffler shop do it for same amount of money maybe even less...Welding is not something that you just rent and can do the first try...But I'm sure if you really want to that you could figure it out and make it work for you...Just have to practice on some scrap metal first...
its do-able, but definately practice somewhere first. its not fun laying on the ground trying to weld the top pieces of the pipe together. i ended up welding everything together on the ground and just clamping the end of the y-pipe to my homemade system for my f-250's exhaust.
good luck
good luck
ORIGINAL: tylerdru
What makes you think all your pipes need to be welded?
How will you remove your tranny if you have too?
A good exhasut system will not leak and will enable you to remove portions of it without the need to replace in case you need to get work done.
I have an 'x' setup that connects to my headers with ball sockets. So it unbolts.
My pipes are also clamped onto the rear outlet of my mufflers. So I can unbolt from the headers, unbolt from the rear pipes, and drop the center section.
Any other joints in the system (like the x itself and the muffler inletss) are welded.
As mentioned, it depends on the age of the pipes, etc. If you are putting on a new system it is best that you have it welded together to prevent any leaks, and to avoid hitting a rock or something and the pipes come apart and get all bent out of shape.
I would recomend taking it to a muffler shop. Welding isn't that hard if you know what you're doing, but exhaust pipes are made from very thin metal, and it will be VERY easy to burn a hole through them, especialy for a beginning welder. Also, if the pipes are stainless, that further complicates the welds. So, I would say to take it to a muffler shop, they will make better quality of welds and it shouldn't cost very much.
94mustang2003
04-01-2004 12:41 AM
