brake & clutch pedal support question !!
Old 08-07-2014, 07:51 AM
mhubert89
mhubert89's Avatar
Default brake & clutch pedal support question !!
hi,
i have a mustang 68 fastback. i just strip my car for a full restoration. Originally my car come with a brake & clutch pedal support for a 4 wheel drums brake !
did i need to change my pedal support & my brake pedal to put some front disc brake with a brake booster ?
thanks
Mathieu
mhubert89 is offline
Old 08-07-2014, 04:15 PM
67mustang302
67mustang302's Avatar
No, it works with disc as well.
What does matter is the m/c you uses, and the pushrod for the m/c.
67mustang302 is offline
Old 08-10-2014, 10:29 AM
mhubert89
mhubert89's Avatar
Oki..one guys told me this ; what do you think ;
"The disc brake pedals are longer than the drum brake pedals and the mounting points are different. The correct brake pedal feel will not be obtained with a drum brake pedal "
Old 08-10-2014, 11:21 AM
Starfury
Starfury's Avatar
To my knowledge, the only thing that's different is the little "disc brake" emblem on the factory disc brake pedal.
Plenty of us (myself included) have swapped to factory disc brakes with no problems. I even went the manual disc route, and I'm perfectly happy with the result.
Starfury is offline
Old 08-10-2014, 07:32 PM
mhubert89
mhubert89's Avatar
oki perfect ! thx for the help
Old 08-14-2014, 08:19 AM
2+2GT
2+2GT's Avatar
You were told wrong.
The 67-73 pedals have nothing to do with whether the car has discs or drums. (On 64-66 cars, there was no difference whatsoever, all cars used the same brake pedals.)
The POWER brake pedal is longer, and mounts at the hole provided in your pedal bracket, at the top. This is true whether the car was a 200 six with power drums, or a 428 CobraJet with power discs. Same pedal. These pedals are available new.
Disc brakes came only as power boost, which has probably given rise to this misconception.
You can certainly convert a Mustang to manual disc, and leave the stock manual drum pedal in the car. Works perfectly, and is preferred by many performance enthusiasts.
2+2GT is offline
Old 08-14-2014, 08:41 PM
MustangsToFear
MustangsToFear's Avatar
Their is a difference between the pedals depending on if it's power brakes or manual. The manual has a higher pivot point.
MustangsToFear is offline
Old 08-18-2014, 10:38 AM
mhubert89
mhubert89's Avatar
i have a power drums brake pedal and put a power disc brake set up !
Good ! so i will restore my power drum support and put it back with my disc brake set up ! thank you , appreciate !
musnicki
09-23-2015 07:11 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
Quick Reply: brake & clutch pedal support question !!
