Gas tank filling issue
Old 11-16-2015, 11:35 PM
teeeeg67
teeeeg67's Avatar
Very cool idea! That's for sharing!
teeeeg67 is offline
Old 11-17-2015, 10:56 AM
movielover40
movielover40's Avatar
My 2005 Mustang has always been bad.
I have to manually add the gas on the lowest setting and some pumps shut off all the time. Really bothers me in cold weather.
movielover40 is offline
Old 11-17-2015, 11:08 AM
groho
groho's Avatar
Tarafied, sorry to interrupt, what is the hole diameter, 1"? Great idea!
groho is offline
Old 11-23-2015, 01:26 PM
shelbymustangdan
shelbymustangdan's Avatar
Originally Posted by tarafied1
I made a plate that I welded into the neck near the opening. It has the same size hole as the unleaded filler nozzle. The filler is designed to auto shut off when it detects back pressure. There is a small hole in the nozzle. You have to be sure the nozzle fits inside the filler neck far enough to get this small hole inside so it will auto shut off. I made the hole for the nozzle slightly lower than center to allow the nozzle to be pointed downward into the tank. I have a 67 coupe and I have driven it on the Hot Rod Power Tour 6 years now and in 16 different states. It seams to work great everywhere I have been. I can fill at full blast and it shuts off automatically without any splash back.
Oh and it has a 429 so it doesn't pass many gas stations
Great idea! Questions: Did you slide that new plate through the existing opening, then welded it? Or did you cut the inlet pipe, weld the new plate in place, the reattach (weld) the inlet pipe end you cut off? How far down from the gas cap did you go? And how large of a hole is in that plate?
Thanks!
shelbymustangdan is offline
Old 11-24-2015, 09:14 AM
bop11
bop11's Avatar
Funny, that you added a that plate. In the late 70's,we were all cutting out a similar plate so we could get the big Un-Leaded gas nozzle in.
bop11 is offline
LordRipberger
10-28-2015 11:53 AM
Dudeman7883
10-23-2015 03:03 PM
ushiee
10-07-2015 09:51 AM
Curls&Horses
10-06-2015 09:09 PM
Quick Reply: Gas tank filling issue
