Sponsored by:
Sponsored by:
How do I access RH lift mechanism?
Old 06-08-2013, 08:13 PM
numnutz
numnutz's Avatar
Question How do I access RH lift mechanism?
Have 03 vert, and when top is being raised, the rh side starts up about 6 inches after left side starts raising, and remains lower past the fulcrum point, and then locks OK. Can I access the lift linkage by removing rear seat top and bottom; or does interior side panel also have to come off,or can I get to it from the trunk or what? Thanks for listening.
numnutz is offline
Old 06-16-2013, 11:22 AM
scan1959
scan1959's Avatar
Num;
You definetly need to take out the bottom and backrest of the rear seat. Then, take off the side panel.
This will expose the hydraulic cylinder.
What are you thinking you will do when you expose the cylinder? Ford says that it's normal for the cylinders to raise at a different level.
As long as both sides come together so you can clamp it in front, I wouldn't worry about it.
scan
scan1959 is offline
Old 06-16-2013, 03:41 PM
Special20
Special20's Avatar
I also have an 03 Vert and replaced both rams and lines due to a leaking ram. There is about a 4" difference in the way they raise and lower but by the time the top reaches the windshield, they are even. The supplyer of the new rams said they will take a little longer to raise and lower. For anyone interested, it takes around 12-13 seconds. I believe OEM is a little quicker.
Special20 is offline
Old 06-17-2013, 08:28 AM
numnutz
numnutz's Avatar
Default repair
Originally Posted by scan1959
Num;
scan
Thanks for the reply,Scan. Never having run into this,I figured part of the lift linkage must be loose or worn,needing repair;but if this is the case, I'm gonna just let 'er be till it quits. Thanks again.
numnutz is offline
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
07-05-2020 03:05 AM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: How do I access RH lift mechanism?
