Sponsored by:
Sponsored by: DashLynx
Bullitt Suspension Kit
Old 07-08-2005, 04:44 PM
suzukidragracer
suzukidragracer's Avatar
Default Bullitt Suspension Kit
Has anyone here bought the Bullitt Suspension Kit from MustangSuspension.com? I've got an '02 GT, stock.
Looks like a good deal to me for $400.00. I'm on a tight budget.
Comes with (4) Ford Racing Bullitt Springs, (4) Tokiko Shocks and Struts, Front and Rear Swaybars.
This plus their Polyurethane Spring Isolators and Prothane Offset Rack Bushings is what I am looking at, should make for a little bit stiffer and more accurate setup than stock.
It's only supposed to lower the car like .75" which is fine with me. It's my daily driver.
How stiff do you guys think this would be?
Any additional input or suggestions would be appreciated!
Thanks,
Vince
suzukidragracer is offline
Old 07-08-2005, 04:45 PM
P Zero
P Zero's Avatar
Default RE: Bullitt Suspension Kit
Depends on the spring rate, cant imagine it would be too stiff if it only lowers the car .75"
P Zero is offline
Old 07-08-2005, 04:58 PM
suzukidragracer
Their site says that the spring rate and drop is very similar to the Ford Racing "C" Springs.
Spring Rating: 650 lb./in. front - 200/300 lb./in. rear (equal to our popular Steeda Sport Springs) Lowers car 1.2 inches front, 1 inch rear.
I've heard that this kit doesn't actually lower it that much, but I could be wrong!
Old 07-08-2005, 06:00 PM
P Zero
P Zero's Avatar
Well its gonna be a rougher ride, anytime you lower any this always happens. If theyre like the motorsport spring then i wouldnt really worry to much about it, and the measurements you gave is the same as the eibach prokit which is a street spring so its not too rough.
P Zero is offline
Old 07-08-2005, 06:22 PM
suzukidragracer
Great. Thanks alot.
I figured that it wouldn't be too rough a ride since it came on the production Bullitts.
As soon as I scrape up some cash, it's MINE!
Thanks again,
Vince
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
Lethaldosage423
10-19-2015 12:12 AM
Matt's 95 Stang
10-05-2015 07:16 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Bullitt Suspension Kit
