Dyno Run Gone Bad?
Dyno Run Gone Bad?
I have a 2007 Mustang GT and it ran like it should before and after a dyno test but while testing it detonated or something. Could the dyno testers have made a mistake setting up the dyno or are dynos a non screw upable device? I just can not figure out why I had a problem mid run but the car was running fine before and after? I am going back today to talk to the owner and see whats what? I don't think I got any damage but how can I be sure? Does a dyno or can it be set to put to much load on an engine; I read that to much load can cause this too. Whatever thoughts yall have I would like to have.
They said they could fix it and that it might need a tune. I took the tune off as far as the engine goes but left the tune for my gears and shift firmness. I hope all it was was that I had a 93 oct tune and the gas I have been getting is not really 93. I will try a run it on the dyno again this weekend and if I can not get in to dyno I will just run it wide open some and see what happens. Sence I took off the tune and the engine is back to stock I should not have any more problems; I hope!! If it still detonates I will have to go from there. Man I hope all it was was the tune.
