Sponsored by:
Sponsored by: DashLynx
Old 11-04-2015, 12:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
how do change fuel filter
Old 08-29-2011, 08:31 AM
kbizzle
kbizzle's Avatar
Default how do change fuel filter
how do i change fuel filter on 2000 mustang and do i have to use the special tool.
kbizzle is offline
Old 08-31-2011, 08:23 AM
Mickjb1980
Mickjb1980's Avatar
You have to unscrew the band clamp around the filter then remove the 2 white clips on each end of the fuel lines they pull out.the pull off the lines,remove the filter from its houseing and repeat to replace. Hope this helps.
Mickjb1980 is offline
Old 08-31-2011, 08:40 AM
99GTvert
is my username.
99GTvert's Avatar
Removing the filter may require a fuel line disconnect tool. The size is 5/16ths I think...get the tool that has its own 'handle' on it (red thing at napa). You can do it with the quarter sized tool but its more of a PITA.
99GTvert is offline
Old 08-31-2011, 04:42 PM
ttocs
ttocs's Avatar
after removing the clips all you do is slide the tool down inbetween the two joints fairly firmly and it should release the spring and pop off. the cheaper plastic ones work fine. Have a towel and maybe a small pan to catch what will drip out as you do it or unplug the fuel inertia switch and then start the car till it drains the lines and dies.
ttocs is offline
Old 09-07-2011, 01:07 AM
SXGT
SXGT's Avatar
I found a video on youtube that did step by step guide.
SXGT is offline
Old 09-07-2011, 06:42 AM
petrock
petrock's Avatar
Could you post up a link?
remember that the fuel system is under pressure, so if you just disconnect the filter a lot of fuel will come gushing out. If you remove the fuel pump fuse/relay or engage the fuel inertia cut-off switch then start the car and let it die, you'll relieve this pressure and only a few drops will come out.
Make sure you wear eye protection when doing this job.
petrock is offline
Old 09-07-2011, 01:37 PM
SXGT
SXGT's Avatar
couldnt find the link. the shut off switch is in the trunk isnt it?
SXGT is offline
Old 09-07-2011, 11:26 PM
petrock
petrock's Avatar
Yes. On the drivers side by the tail light.
petrock is offline
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
whatsup62
10-16-2015 03:07 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: how do change fuel filter
