Sponsored by:
Sponsored by: DashLynx
can i turn axle back exhaust into cat back?
Old 11-11-2014, 03:31 PM
ErikM3.7
ErikM3.7's Avatar
Default can i turn axle back exhaust into cat back?
Hello I have a 2014 Mustang v6 I have the Roush axle backs on it and they sound great but I want them louder and want more gains. When I bought them I tried looking for some roush cat backs but they don't make those for my car. So I was wondering can I get the 2.5 mandrel piping at a muffler shop (that's the size of all the catback piping I've seen of other companies that make catbacks) and attach it to the Roush axle backs to make them into the catbacks since when you buy a cat back exhaust its the same as the axle backs just with the bigger mandrel piping. Will this work or will something go wrong. (Also I don't want to buy an x pipe or headers because I do not want to void the warranty) Thank you
ErikM3.7 is offline
Old 11-12-2014, 03:10 PM
PNYXPRESS
PNYXPRESS's Avatar
No, it wont do what you are wanting. To make your car louder you will have too:
a.) replace the mufflers with some other brand that's known to be louder.
b.) eliminate the cats
c.) change out the h-pipe for a x-pipe
d.) install long tube headers
e.) combination of the above options
PNYXPRESS is offline
Old 11-12-2014, 05:15 PM
yourmom6990
yourmom6990's Avatar
I don't see why it wouldn't work. You're not going to get very much louder just by replacing the tubing though. And the gains would be minimal. If you want it louder, do what Xpress suggested and go for headers and or mid pipe. The amount of money you're going to spend on having a muffler shop fabricate tubing wouldn't be too far off from purchasing a mid pipe or headers. That will get you better gains and more decibels for the money than getting the "catback"
yourmom6990 is offline
Old 11-12-2014, 05:47 PM
PNYXPRESS
PNYXPRESS's Avatar
It won't work for what he wants because if the roush axlebacks are 2.5" and are installed that means the exhaust mid pipes on the car are already 2.5" so he would not be gaining anything except a lighter wallet.
Old 11-12-2014, 06:19 PM
yourmom6990
Wrong. I believe the stock exhaust on the 11-14 v6s is 2.25in. I remember this because when I went to install my cut and clamp pipe, AM sent me the wrong clamps. They sent me 2.75" clamps and they were too big. They then sent the correct ones and they fit perfect which were 2.25in.
Old 11-12-2014, 06:29 PM
PNYXPRESS
PNYXPRESS's Avatar
I thought they stepped up to the 2.5" GT exhaust. My bad.
So how is it possible to run a 2.5" muffler on a 2.25" mid pipes.
Another option is to snag a 2.5" exhaust setup from a GT. you would then just need a shop to fab up a reducer piece to bolt you factory 2.25 to the the 2.5" pipes.
Old 11-12-2014, 06:46 PM
yourmom6990
No, the stock exhaust is 2.25in all the way through. They are able to run 2.5" mufflers because there is a flared end on the muffler which seats the rounded 2.25in pipe properly.
You can see the flange here in the picture of an axle back. The pipes kind of butt together and then are clamped:
http://www.americanmuscle.com/flowma...ck-2011v6.html
Where as a catback system doesn't have a flange because its 2.5" all the way through. The muffler actually slips over the catback piping and is then clamped:
http://www.americanmuscle.com/magnaf...ck-1314v6.html
Now that I think of it, I'm not sure that the piping would just bolt right up to the axle back because of the flared ends on the mufflers. You would have to slice off the very tip of the flared part of the axle back and use an adapter pipe to connect the 2.5"catback pipe.. That would probably be easiest.
To answer the question, Yes. It is possible to do it with the axle back mufflers if the shop knows what they are doing.
Kind of hard to explain without being under the vehicle. lol I think your best bet would be headers and/or midpipe.
Old 11-12-2014, 07:02 PM
PNYXPRESS
PNYXPRESS's Avatar
Yeah sounds like either way the mufflers will need to be replaced or modified to step up to a full 2.5" system.
Old 11-12-2014, 07:09 PM
yourmom6990
I edited the above posting.
It would be possible if you sliced off the very tip of the flared part of the muffler and then used an adapter piece. It would be a fluster cluck at that point though. Mights as well just sell the mufflers and buy the whole catback system.
Old 11-12-2014, 07:21 PM
cruisin5268d
cruisin5268d's Avatar
There's some good information already provided in this thread.
OP, it is important that you have realistic expectations and understand that your car will never have the GT sound. Some people are happy with their V6's exhaust, and that's all that matters. Just don't get false expectations and set yourself up for endless spending while you try to achieve a V8 sound - you might as well trade your car in.
cruisin5268d is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
mirandaandjimmy
11-16-2015 08:51 AM
Evilwilly
08-25-2015 10:30 PM
MustangHead91
08-23-2015 09:37 PM
Quick Reply: can i turn axle back exhaust into cat back?
