how far can you stroke a 4.6L
Does not the 4.6L share the same skirt transverse width as the 5.4L? If so, I think that might be the limiting factor in stroking the engine. But if the 4.6L has a narrow skirt, you cannot stroke it to that desired 330ci displacement. Of course, boring also has its limits. Depending on the cylinder spacing, which I think is uniform on all modular engines, you can only overbore so much before you cause fissures to crack open in the cylinder walls.
I do not know the exact dims of the 4.6L block, but knowing the crank volume space and other block dimensions, you can calculate just how much stroke is too much.
Galactic
04-29-2019 02:56 PM
Gary Ugarek
09-05-2015 09:03 PM
