To those with a rear end gear swap
Old 02-12-2012, 11:03 AM
albino_coyote
albino_coyote's Avatar
Default To those with a rear end gear swap
I was hoping to get better educated on the rear end gear ring and pinion swap.
I have a 2012 5.0, stock 3.31 gears. I am thinking I'd like to go to 3.73...it would have been on the car if I had ordered it. I have a couple of questions:
1. Have most of you used an aftermarket speed shop or the dealership to do it for you?
2. Who is making the best gearsets now? Ford Racing? I'd like to have strength
3. Have any of you upgaded the carrier/differential at the same time?
4. What kind of PCM considerations would I have? Must I buy a programmer just to reset the gear calibration to get the speedo and mileage correct???
5. For those that remember, what was your parts list to do the job?
albino_coyote is offline
Old 02-12-2012, 12:43 PM
MurrietaStang
MurrietaStang's Avatar
I had mine changed 3 different times from 2 different shops (not the dealership). The first time I went with 4.10s and it whined. had the shop do the install again at no cost and it still whined. These guys were known for doing this too and even had an article in one of the mustang mags on it. Then tried 3.73s at another shop and the whine isn't as bad but, it does whine a little around 60 to 70 mph. All three times the shops said they used the FRPP gears, not motive. If I end up rolling the dice again and trying another set I'd probably just get the Boss302 rear axle assembly which comes with 3.73s, better traction lok diff, and 31 spline axles. That and it's a new assembly, mine is all rusted all over the place. I believe FRPP still makes the best gears but, you have to make sure you're not getting the FRPP gears that were made by Motive. You will need to get a tuner to recalibrate the gear ratio.
MurrietaStang is offline
Old 02-12-2012, 12:50 PM
kzonts
kzonts's Avatar
I upgraded my 7.5 to 3.73s and T-lok. I ordered the Ford Racing gear kit from StangMods and it's been rock solid. No noises at all. For the installation I went to a speed shop which specializes in Mustangs. The only thing I did was change the gear oil after a thousand miles - I used Royal Purple. No complaints here.
kzonts is offline
Old 02-12-2012, 03:53 PM
99gtstang
99gtstang's Avatar
I used a mechanic that did rear ends for ford. I recommend a speed shop.
I've had gears in two and used ford both times.
3. Have any of you upgraded the carrier/differential at the same time?
The installer did not recommend replacing anything else due to mileage; 25K. My last car I put gears in a 120K and replaced all seals/bearing.
I would recommend just getting the SCT from AM and use the free Bama tunes for life. You can buy a speed recalibration tool... but is that all you want? If so, I would not even but that... who cares how fast you're going
[B]I've read and heard it's a hard job for a newbie. I have not attempted to do this job, so I cannot comment.
99gtstang is offline
Old 02-12-2012, 09:49 PM
albino_coyote
Thanks for these comments. You are right, the tuning won't stop with gears...but just want to keep the install cost effective as possible....the tax refund only goes so far if you know what I mean!
Old 02-21-2012, 04:03 PM
dymd3z
dymd3z's Avatar
Default Mustang Gear
Hey, I was just curious if you have found a shop in Birmingham, AL who could install a ring gear in the mustang? I am trying to find someone in Birmingham who does quality work and able to install a 410 gear in my Mustang. If you could please let me know I would highly appreciate it.
Thanks
dymd3z is offline
Old 02-21-2012, 09:45 PM
tx_zstang
tx_zstang's Avatar
Find a good EXPERIENCED shop, or a ford dealer with an experienced tech.
There's a proper procedure for properly installing a set of gears, and a lot of shops don't follow those steps and end up with noisy gears or early failures. You dont want that.
(ask how they install the pinion nut, about preload, etc. If they just impact the pinion nut on, go somewhere else. period.)
FRPP gears are still the only ones I use. They can be a little whiney at certain speeds, depending on exact backlash ring gear during install.
tx_zstang is offline
msavoia23
12
07-07-2018 12:08 PM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
ding56
08-14-2015 02:40 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: To those with a rear end gear swap
