Can't turn off my tcs
Old 06-04-2012, 09:01 PM
Shelby305
Shelby305's Avatar
Default Can't turn off my tcs
i have an 06 gt. when i first got my car my dad didn't want me to mess around with it so he found a way to permanently leave on the tcs. Now he can't remember what he did, so it's stuck on. i took off the radio and everything in the center trying to look for an unplugged cable or something but found nothing. Any other ideas?
thanks.
Shelby305 is offline
Old 06-04-2012, 09:07 PM
Shelby305
Shelby305's Avatar
can i solve my problems by just buyin a tuner from AM? i heard i can disable traction control on that.
Old 06-04-2012, 09:09 PM
Nuke
Nuke's Avatar
Check the wiring diagram. It defaults to "on" so it's either disabled at the switch or in line. I'm not sure if there's a relay involved so you'll have to look up the diagram in here: http://iihs.net/fsm/?dir=1
Nuke is offline
Old 07-06-2012, 08:58 AM
Shelby305
Shelby305's Avatar
that wiring is chinese to me man.. any other suggestions?
Old 07-07-2012, 03:19 AM
Diabolical!
Diabolical!'s Avatar
Find an electrician. They speak Chinese. Seriously though, if you can't read the diagrams, what good does it do to go fishing in the harness?
Diabolical! is offline
Old 07-07-2012, 07:30 AM
Nuke
Nuke's Avatar
Although I didn't see it in the diagrams under Engine Controls, I suspect daddy may have disabled a relay. Since the TCS will default back to "on" after shutting off the ignition and starting the car again, it tells me there's a relay and that would be my "guess" to where he did his deed.
Nuke is offline
Old 07-16-2012, 05:16 PM
Shelby305
Shelby305's Avatar
real funny, have you taken off the radio in your car? it's just a few plugs. why do you post if youre not trying to help? idiot..
Old 07-16-2012, 07:15 PM
Nuke
Nuke's Avatar
Shields up, shelby305. Diabolical was being sarcastic in a friendly way. You'll get that a lot here but it's rarely meant to **** one off.
If you truly can't read the wiring diagrams and haven't a clue where to look, then I suggest you stop by a dealership and explain what you want to a tech. Playing with wiring based on mere guesses is bad joojoo.
Nuke is offline
Old 07-17-2012, 09:24 AM
siggyfreud
siggyfreud's Avatar
You're here seeking free advice, so be polite. This is an electrical issue, and if you don't understand electronics, or how to read the diagrams, that's fine, but find someone who does, as you can really screw some stuff up by poking around in wires where you're lost.
siggyfreud is offline
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
09-30-2015 12:39 PM
logan409
09-26-2015 07:43 PM
Quick Reply: Can't turn off my tcs
