Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
8 rib pulley, belt dressing-ANDERSON MOTORSPORTS
Old 06-25-2007, 07:10 PM
sfi
sfi's Avatar
Default 8 rib pulley, belt dressing-ANDERSON MOTORSPORTS
Has anyone used the 8 rib pulley kit on there procharger or the belt dressing they advertise that helps belt slips by Anderson Motorsports.My belt slips only until it get warm uped. There seems to be alittle play, but Im sure the tensioners is not maxed out > I plan on replacing it , but I don't really know if thats the problem. Any help would be appreciated.
sfi is offline
Old 06-27-2007, 01:59 AM
ruffrider4403
ruffrider4403's Avatar
Default RE: 8 rib pulley, belt dressing-ANDERSON MOTORSPORTS
dont knowwhat everyone else has to say but ihad belt slippageso i bought a can of belt dressing and coated my belt. it snapped week later, 20 miles out of a belt, not bad....... if you dont have to use belt dressing, dont. take the belt off, clean all your pulleys and make sure you dont have anyoil leaks that could leak onto the belt.
ruffrider4403 is offline
Old 06-27-2007, 03:13 PM
luckythirteen13
luckythirteen13's Avatar
i tried belt dressing once for my accessory belt and it worked for about 5 minutes. the belt is probably too loose. 8 rib belts dont usually slip unless your sc pulley is incredibly tiny, the belt is shot, or the belt isnt tight enough.
luckythirteen13 is offline
Old 07-06-2007, 01:15 AM
sfi
sfi's Avatar
The belt seems to be in great shape, the tensioner is the possible problem. Is this something easy to change.
sfi is offline
Old 07-06-2007, 11:59 AM
luckythirteen13
ORIGINAL: sfi
yes. i hated having the stock tensioner. it was a pain because it didnt put enough pressure on the belt. i ditched it all together as you can see in the pic in my sig. i made a tensioner rod and never looked back
Old 07-08-2007, 08:24 AM
contentsunderpressur
contentsunderpressur's Avatar
I have a P-1 with a 3.4 pulley with no slip at all. Your sig says your running 8lbs of boost which shouldn't slip at all. If you didn't change the tensioner when you installed the charger then that's probably your problem. A friend of mine run a 3.2 pulley without slipage. He then swaped over to the 8 rib setup and is now running a 2.75 pulley with no problems. You have a big problem if your sliping on a 3.6 pulley.
contentsunderpressur is offline
Old 07-08-2007, 09:46 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I have never used belt dressing for anything. It's not a fix and makes things worse. I have a p-1 8 rib as well. I have already replaced the stock kit tensioner once. So far, no problems. They do need to come out w/ a better tensioner though.
PRO50SC is offline
Old 07-08-2007, 01:24 PM
Frostbitten
Frostbitten's Avatar
belt tensioner......
Frostbitten is offline
Old 07-08-2007, 10:29 PM
sfi
sfi's Avatar
thank you. It doesn't happen all the time, but I should of changed it when I had the install done. Does anyone have the anderson 8 rib pully set, and if so, where dod you get the belt and spacer for the pully ??
sfi is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
spdeplayer2
10-24-2015 09:45 AM
FivePointToTheOh
09-29-2015 12:53 PM
Quick Reply: 8 rib pulley, belt dressing-ANDERSON MOTORSPORTS
