Vortech install questions
Does anyone have a close up picture of the oil feed and discharge lines going into the supercharger? I have a larger hole on the top of the charger and a smaller one on the bottom with no fittings in either. How do I attach the 2 hoses. On the feed line it says to use the 45degree fitting, which if I am using the right one I can't get to fit.
Also I was trying to put the blue fitting onto the MAF and I can't get the damn thing to fit. Can I buy a larger fitting at the auto store, and will this cause any issues?
It is one of the silicone sleeves that connects the MAF to an elbow? Pictures would be much appreciated.
Also how do I attach the blower pully to the shaft? I see there is a groove on the pully and on the shaft. Am I supposed to line those up and force it on there? These are all probably rookie questions so I appreciate the patients.
I am just answering my own questions here.
woodruff key.
contacted vortech and they are sending me the nozzle for the intake and the fitting for the discharge. I could only find these through vortech.
When using a 90mm MAF a 4" to 3.5" fitting is required, the stock fitting will not work.
I guess it is a good thing I can answer my own questions since I never got any help
i just saw this, be carefull to make sure you dont over tighten the oil feed line, i used liquid teflon and made it snug, at first i overtightened it and it broke off inside the sc, $70 later for a new one, i also bought a nipple to extend the connection to the hose further away from the sc so its easier to tighten
I found anouther issue. When installing the blower and mounting hardware i was hitting the factory idler pully. After calling vortech I found out their pully is a 2.6 where the stock one is 3.0. I went to napa and got it for $30.
the idler pulley that came with mine was hitting the alt, i filed it down the back at first which made it work but it made so much noise i thought the sc was broken, i then bought a stock one since that is what they show in the installation pic and had no problems.
All of this info is most def good to know. Eventhough I didn't start the thread thanks for the info..
The Idler pully I was refering to in my last post is the ribbed one about half way down on the left side (if looking at the front of the motor) It does not come with the kit from superchargers online and has to either be ordered seperately or from an auto store like I did for much cheaper.
I had 1 more issue last night, I got the blower and all the piping on then went to start the car and nothing. I believe the fuel pump I bought is bad. I guess there are only so many things you can buy used. I need to find me a 255lph asap.
Shifty Magoo
08-25-2015 03:08 PM
Soldier GT
08-12-2015 03:46 PM
