Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
6 rib Kenne Bell S/C belts...
Old 02-20-2011, 09:59 PM
ScoobyStang452
ScoobyStang452's Avatar
Default 6 rib Kenne Bell S/C belts...
Ok, this seems to be something of an anomaly. I seem to be cycling through S/C belts every Summer. Gets worn out and squeals like a pig. Do I need to make some adjustments so I get more life out of the belt? Or is this just something I'm gonna have to live with?
My driving style isn't abusive by any means. Its babied for the most part while I'm driving around. I don't try to slam the gas pedal through the floor board through turns or try and street race at all. Once in a while I will open her up on an open freeway or back roads. She's seen TWO track days of which only one was with the blower on.
Any takers?
ScoobyStang452 is offline
Old 02-26-2011, 11:27 PM
Mach1man
Mach1man's Avatar
You sure it's the belt and not an idler pulley that's gone bad?
Mach1man is offline
Old 02-27-2011, 07:33 AM
ScoobyStang452
Pretty sure.
My testing capabilities are pretty limited but I gave all the pullies a cursory look to make sure there wasn't any play or rubbing and catching when I changed the belt out last. After it's changed out it was fine. I'm kind leaning towards then tensioner
p51pony
12-02-2015 10:02 PM
spdeplayer2
10-24-2015 09:45 AM
MasterLanMan
09-26-2015 10:03 AM
hookergt
09-04-2015 06:57 AM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: 6 rib Kenne Bell S/C belts...
