Steeda Sport Springs installed on 2011 GT (pics, 56k warning)
Old 10-25-2010, 05:11 AM
JV Doose
JV Doose's Avatar
looks great!
i'll be waiting for that write up
JV Doose is offline
Old 10-28-2010, 07:16 PM
lcowart
lcowart's Avatar
Your car looks great. I am thinking about doing the same thing to my 2010. My question is do you have to do shocks if you do the springs or can you leave the factory ones on? Thanks.
lcowart is offline
Old 10-28-2010, 08:13 PM
jsnyng
jsnyng's Avatar
Thank you for the compliment. I'm running on factory shocks/struts. You don't have to change them.
jsnyng is offline
Old 10-29-2010, 11:29 AM
Sam Strano
Former Sponsor
Sam Strano's Avatar
You certainly don't have to change the struts and shocks out.... but it ain't a bad idea. The stock stuff is meant for stock springs (taller, and generally softer) than the lowering springs. The shorter, stiffer springs need more rebound damping to control that higher rate in a shorter amount of travel.
Have a new car.. that's the best situation in which the stock dampers will work. And remember that not all stock dampers are the same. Brembo cars have upgraded (if not ideal) dampers vs. non 2011 Brembo cars which make them better able to deal with lowering springs--at least for a while.
You absolutely can run lowering springs with stock dampers, it just doesn't work as well, especially as the miles pile on. Eventually you'll want to upgrade, might not be right now.
Sam Strano is offline
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
robjh22
08-17-2015 07:35 AM
11GTBlu
5.0L V8 Technical Discussions
08-10-2015 05:56 PM
Quick Reply: Steeda Sport Springs installed on 2011 GT (pics, 56k warning)
