Diagnosing the Clunk - Struts changed... next...
Old 05-13-2016, 08:06 AM
Chromeshadow
Chromeshadow's Avatar
Awesome, thanks for the update!
Chromeshadow is offline
Old 05-13-2016, 09:51 AM
Sgkukov
Sgkukov's Avatar
Originally Posted by 09GT/CS
Well it was the end links when I did my shakedown test (no weight on suspension) it all seemed tight. Pulled the drivers side link and there was so much slop in the passenger side I could move the sway bar about half an inch up and down. Put some moog links on it. They were pricy but much beefier than the stockers. Noise is gone now.
So the sway bar end link ball joints were loose?
Sgkukov is offline
Old 05-13-2016, 10:14 AM
09GT/CS
09GT/CS's Avatar
Yeah the right side upper where it mounted to the strut. I'm surprised it didn't separate.
09GT/CS is offline
Old 05-13-2016, 02:26 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Having chased this type of problem/noise on my own car, often times it's a combination of things. All you are left with is the sway bar bushings themselves.
I changed those (last item on my list) and viola, noise completely gone.
Same thing happened on our 06 escape, clunking on the front end, did control arms and struts, tie rods, sway bar end links. almost completely quiet except for the say bar bushings. Replaced those on the Escape, all noise gone, just like the stang.
Derf00 is offline
Old 05-15-2016, 05:57 AM
Sgkukov
Sgkukov's Avatar
Were the sway bar bushings noticeably bad? I was going to do mind but they seem fine.
Sgkukov is offline
Old 05-16-2016, 07:32 AM
Norm Peterson
Norm Peterson's Avatar
It's also possible for the bushings to be good but for the nuts/bolts securing the clamps to have loosened. I don't think that this is a very common source of noise but it absolutely can happen, perhaps more likely once you've removed and re-installed these fasteners because you swapped out the OE front stabilizer bar for an aftermarket one. Been there (and the dealership either couldn't find it or didn't put enough time into finding it when I had the car in for other service).
Norm
Norm Peterson is offline
Old 05-16-2016, 08:26 AM
Chromeshadow
I had that happen after I replaced the factory bushings( and sway bars). I used locktite the second time.
Old 06-08-2016, 01:37 PM
Sgkukov
Sgkukov's Avatar
Just an update - new outside tie rod ends, alignment and wheels rebalanced seems to have greatly helped
Sgkukov is offline
Old 08-01-2017, 09:23 PM
gbrueckner
gbrueckner's Avatar
I changed EVERYTHING - twice - on both sides and still had the noise. I found the bolt holding the bottom ball joint shaft was damaged - and the passenger side ball joint was damaged. I had changed the ball joint twice so I assumed it had to be good but it wasn't.....
gbrueckner is offline
Old 08-01-2017, 09:28 PM
gbrueckner
gbrueckner's Avatar
In trying to get rid of the noise I also tried to just suppress it by filling the frame under the door sills with expanding foam, putting insulation in in any space behind the plastic panels and wrapping the stabilizer bars and control arms in pipe insulation - they all worked so now its a very quite ride.
03Gstang
West
06-13-2006 05:44 AM
chavalo_nm1
05-13-2006 10:37 PM
Voodoo
12-19-2005 11:05 PM
HokieStang
10-10-2005 11:11 PM
Cheihachi
03-14-2005 05:38 PM
Quick Reply: Diagnosing the Clunk - Struts changed... next...
