2005 Saleen Kit
RE: 2005 Saleen Kit
I actually had to take mine off, and dremmel out the holes because the fit was poor. The ducktail was about 1/3" higher than the quarter extensions and looked as if the trunk wasn't closed tight. I also didn't like the fitment at the very edges, so I added two more screws of my own from the INSIDE of the trunklid, into the mounting brackets of the ducktail. That didn't really make it more sturdy, just helped to pull it down even with the quarter extensions.
There are only 4 or 6 bolts that hold it on, and if you put it on yourself you should know where these are - if you didn't, look at the bottom of the trunk lid and tighten them all up. Two bolts are hidden under the plastic cover that houses the trunk latch and the light.
RE: 2005 Saleen Kit
at one point in my life i hade 4 screws plus tape, now im down to two(assuming cause of the shaker 100 vibrating). Do you guys know what size the screws are so i can put some more in?
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
