SVT Forums
97 cobra smog pump?
Old 04-03-2009, 10:23 PM
Reikat
Reikat's Avatar
Default 97 cobra smog pump?
Well I just bought a 97 svt cobra and on the drive home it threw a chack engine light. I checked the code and it was p0411, which after a few minutes on google I realized was quite a common code. It has to do with the smog pump some how being faulty. Mainly it's just emissions bs. But I deleted the code hoping it was just coincidence, as the car had mostly been sitting for 8 months. But it came back on after about ten miles or fifteen miles. so I decides I need to check and maybe replace the smog pump, but the thing is, after searching on the internet and my hanes manual, I can't find where it is, or how to take it off... if you guys could maybe shed some light in general on my situatuion, that would be awsome.
Reikat is offline
Old 04-03-2009, 10:34 PM
JK59GT2000
Banned
JK59GT2000's Avatar
bypass it!...or is that just something 5.0's do?
JK59GT2000 is offline
Old 04-04-2009, 06:04 AM
Reikat
Reikat's Avatar
well, scince it's not belt driven I don't think it is as easy as just removing it. I read somewhere there is a delete kit or something, but I can't find that either. It also just seems easier to replace it if I'm gonna spend a lot of money on a kit to delete it...
But I'm gonna go look a little harder for it todat when I detail my engine bay, so I hope I can atleast find where it is, even if I can't figure out how to replace it... I'm not even 100% sure how much it costs... lol
Reikat is offline
Old 04-04-2009, 02:23 PM
JK59GT2000
Banned
JK59GT2000's Avatar
all i have found is an ac delete kit not smog pump delete.
Old 04-06-2009, 05:47 AM
Ehmark
Ehmark's Avatar
Check the fuse under the hood. The pump is hard to find, I have one for sale cheap or you could get custom tuner and have car forget it ever had the pump as well as gain a few HP.
Ehmark is offline
Old 04-07-2009, 07:15 PM
Blackvenom01
Blackvenom01's Avatar
i say tune it to forget it unless you have emitions testing where you are
Blackvenom01 is offline
Old 04-08-2009, 04:25 AM
Ehmark
Ehmark's Avatar
You can get by the smog with a tune, it will say N/A not fail when they scan the computer. Then the retared CA smog inspecter with the lisp will say "Thats funney Ive never seen that before." I mean Its not like im speaking from experience or anything ; )
Ehmark is offline
Old 04-30-2009, 04:50 PM
cobrabite97
cobrabite97's Avatar
Default same problem
the pump should be under the passenger side front bumper by the radiator support....it's stupid and all it does is send air to your exhuast to burn up extra fuel in your cats..it's like 100 buck for the new pump but i'd check your fuse's first cuz thats kinda common too
cobrabite97 is offline
Old 05-02-2009, 03:17 PM
GeoJeff05
GeoJeff05's Avatar
The smog pump is located in the passenger side fender well. Remove the stock air cleaner assembly and look in the hole in the fender where the intake draws air from, it is just below this. It is electronically controlled and if bypassed by simply unplugging it, you will not see any driveability issues. All it does is inject fresh air into your exhaust system to optimize catalyst efficiency, thus reducing emissions. I have a 97 cobra and I have bypassed mine with no ill affects.
GeoJeff05 is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: 97 cobra smog pump?
