Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Check My data log?
Old 01-30-2014, 09:10 PM
shinerttu
shinerttu's Avatar
Default Check My data log?
So Bama sent me a config file to datalog my car bc of a pinging issue. Everytime I loaded it though the PID's failed to load. I called SCT and they told me to manually select them. I tried my best to search for the PID's and I'm not exactly sure if I got what he wanted. Anyways I just emailed it off, but while I wait I wanted to postmy data logs. This is my first time and I read that this software is buggy and isn't great at capturing long sections of data so I broke it up the data logs.
I ran and saved files of each of the following
- 2 idle runs
- 2 (3-5 min) normaal drving
- 2 WOT (I definitely heard a ping at top of 2nd gear first run but not sure about 2nd bc I had windows down
http://www.filedropper.com/idle293r_1
http://www.filedropper.com/drive193r
http://www.filedropper.com/drive293r
http://www.filedropper.com/wot293r
http://www.filedropper.com/wot193r1s...dpinghighin2nd
shinerttu is offline
Old 01-31-2014, 11:07 PM
q8stang
q8stang's Avatar
you didn't log a lot of vital parameters, what fuel are you running?
q8stang is offline
Old 01-31-2014, 11:12 PM
shinerttu
shinerttu's Avatar
I'm running shell 93 octane... I was given a config file tht didn't load the pids so I did my best to search for all of the pids on my config file. Can you specify which parameters I am missing? Thanks
Old 09-12-2014, 08:17 PM
JCON
JCON's Avatar
I am interested in knowing which PIDS/DMR's work for the S197's. Specifically related to the fuel system.
JCON is offline
11-18-2015 01:34 PM
10-07-2015 07:02 PM
uedlose
09-10-2015 03:30 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Check My data log?
