How Much Should an 8.8" Rearend Swap Cost????
I know I don't need the brakes and shocks (have 11.65" Mach1/Cobra rotors already and gonna have Tokico D-Specs before the swap). What about the control arms? I'm looking to do just the rear end swap at the moment - not gears, stronger differential, or hardened axles.
Quad shocks suck, as long as your replacement rear is the same generation, it's a direct swap, takes about 30 minutes. You don't even have to disconnect your brake lines, just unbolt the calipers.
Also thanks for the info everyone.. but how much $$$ should the rear end be? The average on the net is around $600... from mps and ebay, can't find one on craigslist for my area. Would I have better luck at teh junkyard? I thought it shouldn't be more than $300.
Sorry for the thread revival, but I've been busy working. Anyways, Ryan that's cool, but not likely for me. Shizzle got an 8.8"... maybe he'll chime in??? (anyone else is welcome as well)...
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
