Overdrive
RE: Overdrive
o/d is 4th gear in the autos. if you turn it off, you waste gas. leave it on and if you want to downshift, pedal to the metal and your computer will downshift for you. if you turn off o/d, you will run insane high rpms at cruising speeds and just burn gas extremely fast
RE: Overdrive
You don't need better performance if you're just cruisin. If your going to race, when you punch the tranny will downshift a gear or two, and away you go. So leaving it off will do you no good unless you are at 100+ MPH when the tranny is wanting to shift to the O/D.
RE: Overdrive
od is around .72:1 and is 4th gear. turning it off just blocks the tranny from up-shifting into 4th
3rd is 1:1
OD turned off will only help you stay in the powerband at about 80+mph in third. it won't help performance under that speed nor does it affect any other gears performance
turning the OD off does nothing to help off the line acceleration nor will it help a stock geared stang in the 1/4 mile
3rd is 1:1
