Old 10-27-2015, 11:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrain
Print Wikipost
"Radiator Flush" question
Old 12-09-2010, 01:29 PM
MustangSally94
MustangSally94's Avatar
yea, im guessing im going to have lol.. how much antifreeze do i need to do this?
MustangSally94 is offline
Old 12-10-2010, 12:52 AM
petrock
petrock's Avatar
Originally Posted by XtremeOracing
A lot of people half *** the job and don't drain the entire system, I like to do it right. IMO do it like the manual says.
You could do it that way, but I prefer to pull the radiator hose at the bottom of the motor. The rest of the fluid will come out quickly, and its a lot easier to get to then the plug on the side of the motor. I think there are two plugs btw (one on each side)
petrock is offline
Old 12-10-2010, 12:56 AM
petrock
petrock's Avatar
I don't know the exact amounts. Best to buy 2 or 3 jugs of pure anti-freeze, which will make 4 to 6 gallons when mixed 50:50 with water. I also prefer distilled water over tap (less contaminants in the water). If you don't want to mix your own, you can buy jugs of pre-mixed antifreeze, but your just paying extra for water… Good luck…
petrock is offline
Old 12-10-2010, 08:15 AM
MustangSally94
actually suprisingly the advanced auto parts by my house sells their brand pre mixed for $5 cheaper then pure antifreeze. So my final question is this cause I wanna make sure I understand something. The bottom hose coming out of the radiator, is that going to drain the fluid out of the block too? Cause thats the hose I gotta replace. Just wanna make sure i do it right lol
Old 12-11-2010, 11:57 AM
mustangman02232
mustangman02232's Avatar
i flushed mine, its called a garden hose, keep draining the rad and refilling till it has all water in the system, allowing it to circulated when the tstat opens, after you have pure clean water re drain and refill with straight antifreeze, it will mix with the water in the system and should come out to just about the perfect level, you can test it to see if you need more water or anti freeze
mustangman02232 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
UrS4
09-30-2015 10:13 AM
Drastang
09-30-2015 03:48 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: "Radiator Flush" question
