Got everything back together after replacing leaky lower intake gaskets. While reading the factory service manual on torquing down the upper intake bolts I noticed that it says to add a dab of teflon sealant to the threads of the bolts. Huh?!?! Why? The bolts don't cross through any oil or coolant passages, as far as I can tell. And the bolt wholes bottom out in the lower intake. So what is the sealant supposed to seal? Am I missing something here? Thanks...
I would just slap some never-sieze on em and get to work. Just be careful, the torque specs are really low.
Thats what I figured. Two different types of metals and all. I went dry, though, cause they were dry when I removed them. I'll redo each bolt individually and apply some anti-sieze to the threads. I also always use a torque wrench when the manual calls for it. :-) First tighten to 88 in/lbs, then 15 ft/lbs then 23 ft/lbs. I used Fel-Pro gaskets, so it should be re-usable. Especially since it looks like the upper intake gasket is some kind of plastic.
Originally Posted by l_shizzle_l
Are you sure you're not mixing up your teflon with your anti-sieze? I don't recall them calling for teflon on them.
According to page 03-01A-15 of the '98 Mustang Factory Service Manual, it states "NOTE: Apply a light coat of Pipe Sealant with Teflon D8AZ-19554-A or equivalent meeting Ford specification WSK-M2G350-A2 and ESR-M18P7-A to retaining bolts and stud bolt threads prior to installation."
