Got a good one for you gear heads
Old 08-18-2007, 05:14 PM
McBudd
McBudd's Avatar
Default Got a good one for you gear heads
So when ford releases their new Boss engine, how much work would it be to drop it into our V6
Might have some major funds coming in soon and was think of maybe looking into that
McBudd is offline
Old 08-18-2007, 06:29 PM
NickSezz
NickSezz's Avatar
Default RE: Got a good one for you gear heads
Off the top of my head....Engine, mounts, computer and wiring, stronger trans and torque converter(auto might hold), 8.8 rear because the 7.5 will probably let go, suspention to compensate for the extra weight, ummmm a lot of little stuff....
Any engine swap this drastic will need a lot of time, work, and money....Its just better to start with the bigger and better car then to make it from scratch, unless thats the challenge your looking for. People have done things like this before so it is very possible.
I personally think there is more value going FI with the 4.0 then going the rout your considering.
NickSezz is offline
Old 08-18-2007, 06:32 PM
chrisc
chrisc's Avatar
I am really not sure, but I can safely say this: if money is an issue, you don't want to do it
chrisc is offline
Old 08-18-2007, 07:25 PM
lrgnation
lrgnation's Avatar
8.8 Take off= $800~
9" Currie ford $2500~
Aluminum Driveshaft $4-600
Wiring Harness?
Computer?
Transmission? t56 maybe
Motor from ford?
Aftermarket Mounts
lrgnation is offline
Old 08-18-2007, 07:47 PM
basketballord
basketballord's Avatar
All I have to say is that would be one kicka$$ stang
basketballord is offline
Old 08-18-2007, 09:55 PM
Bandit111
Bandit111's Avatar
Is the boss crate motor gonna be something like this?http://www.evoperform.com/shop/index...roducts_id=230
Bandit111 is offline
Old 08-19-2007, 03:03 AM
chrisc
chrisc's Avatar
is the boss even a full motor? i was under the impression that it was just a block? i may be wrong [:-]
chrisc is offline
djbigskrilla
09-20-2022 01:04 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Stilz
08-19-2015 06:17 AM
Quick Reply: Got a good one for you gear heads
