Coolant leak
Old 11-06-2013, 08:59 PM
12bjlo
12bjlo's Avatar
Default Coolant leak
I bought a 2006 v6 mustang and the coolant is going fast. I checked my oil and there is no coolant but I have that sweet smell in my exhaust. Anyone know whats up with it?
12bjlo is offline
Old 11-07-2013, 05:59 AM
Moderator
JimC's Avatar
Most likely you have a cracked thermostat housing. The plastic housing is a common failure, and hard to predict when it will go. My 2006 got to 199,881 before the housing cracked, others have had to replace it at 30,000 miles. Look at the back side of the housing and it is probably blowing coolant back into the valley under your intake manifold.
The swap is easy to do, and there is now an aluminum replacement available also (aftermarket not dealer)
JimC is offline
Old 11-07-2013, 09:09 AM
kevinmalec
kevinmalec's Avatar
The thermostat housing is known to fail due to being made out of plastic. The upper and lower are sealed together and with the heat, it splits and the coolant starts too leak trough.
Also, cracked hoses, hoses not clamped correctly or reservoir cracked will cause coolant leaks.
Worse case scenario is a cracked head, which requires an immediate fix!
I replaced my thermostat housing 6 months ago, however I am still experiencing a leak somewhere, but not sure where!
kevinmalec is offline
Old 11-07-2013, 11:04 AM
IvanRad
IvanRad's Avatar
join my thread in the 4.0 section we will save you a couple of bucks.
IvanRad is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Coolant leak
