brake caliper paint/bullitt grille?
would it be okay to use black caliper brake paint on the satin surround on the bullitt grille?
I like the grille but not so much a fan of the satin surround..I want a stealthier appearance ,so the black paint would do fine.
All I do is sand it down a little bit then paint it straight up,correct?
I believe the caliper paint is an epoxy paint made to withstand heat and chipping. It also can be rather thick and has a limited working time. I would use a normal automotive spray paint (Duplicolor or similar) for what you want to do.
I've used that semi-gloss from Krylon on plastic.Get some adhesion promoter for the plastic so the paint doesn't flake off.Scuff it with some scotch brite and use a tach cloth to remove the fine gritty particles or blow it off with compressed air.
Matt's 95 Stang
10-05-2015 07:16 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
09-25-2015 06:42 PM
