HIDs flicker when engine is running??????? HELP
I spoke to the seller about the relay harness because of the disclaimer on their site... He said that everything comes included in the kit for the HIDs I bought.... ,I questioned again and again he said everything will be fine.
Still no reply from seller!!!
Thanks again everyone
Certainly rather lack-luster CS on their part, but the issue is pretty cut and dry given that it functions fine on battery. This is very well documented issue with more modern can-bus vehicles.
I´m a bit fuzzy here, you did state that everything is not fine, right? As in they flicker while the car is running now? Unless this is a support line call routed to a 3rd world nation, I´d think more than a few calls per day/week would be about this issue.
So if you really wish to keep/install them, I´d get their kit or one of the many others sold if you have the model # and you wish to have an in-line matching solution. Or you can just make a cheap solution yourself from the info provided.
OKay, so I finally heard from Dante at HIDGUY, where I got the kits. He said that I do have the relay harness, however, apparently I need the cancellation kit to stop the flickering.
I need to send back my fog light kit as they are the wrong size (my fault), so he is sending out the new fogs and the cancellation kit as well. I shall update when all arrives!
Fingers crossed
Fingers crossed
Gary Ugarek
63
12-11-2015 02:01 PM
inyadreems
08-21-2015 09:10 AM
