Web-Electric Sequential Splice in lights
Old Mar 17, 2006 | 12:30 AM
Stroken97's Avatar
Stroken97
Default Web-Electric Sequential Splice in lights
I add sequential lights from Web-Electric and they work great except I have been unable to get the inner light to work in sequence or as a brake light. On the 2005 is the inner light only a running light? Has anyone else install this product STS-1M Mustang Sequential Turn Signal from Web-Electric? It was an easy install and good directions, but I am think I need to change out the socket.
Old Mar 17, 2006 | 02:28 AM
Tres Wright's Avatar
Tres Wright
Default RE: Web-Electric Sequential Splice in lights
Yes, I've got it on my '05 and all three lamps on both sides work as running lights, brake lights and turn signals. When you turn on the turn signals, you should have 3 lights sequencing. Did you install the extra wire lead to the inner bulbs? If so, check to make sure you're using the right bulbs (they need to be dual filament) and that they are aligned properly in the sockets. Check the metal terminals in the socket and compare it to the metal "blobs" on the bulb to make sure it's all aligned properly (keep in mind that the bulb twists into place, so you'll have to estimate it's true position).
Old Mar 17, 2006 | 09:39 AM
jbailer's Avatar
jbailer
I have the WebElectric splice-in sequentials too. My inner light works fine. Make sure you got that metal conact pushed all the way into the socket. In the instructions they even mention you might need to use a pair of needle nose pliers to push it all the way in. It is the yellow wire with the metal tab on the end. -Joe
Old Mar 17, 2006 | 12:09 PM
Wicked Pony's Avatar
Wicked Pony
I have this kit too and they work great, check the connections, you might have a bad kit
Old Mar 24, 2006 | 04:13 AM
2006GT's Avatar
2006GT
I had the same problem with mine. To remedy it, I took that large metal tab and crushed the bump on it with some heavy duty pliers to make it flush with the rest of the tab, allowing me to push it all the way in. it was impossible to get it all the way in without doing that on my kit. now it works fine.
Old Mar 24, 2006 | 11:12 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
ORIGINAL: jbailer
Ditto on this - one of mine worked and one didn't when I first installed. I pulled the metal lead (on the supplied yellow wire) out of the socket, and reinstalled it a little more FIRM with the needle nose and worked. So unless you are missing the dual filament bulb as mentioned above, just re-seat that lead to make good contact. And obviously, don't re-install the light fixtures to the car until you got them working
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
