Getting off the line!
Old Mar 30, 2006 | 12:01 PM
Tracedaddy's Avatar
Tracedaddy
Default Getting off the line!
OK. This may seem like a silly question but I've never really driven a car with a manual transmmission that had any power to speak of, so it's never been an issue.
What the best technique to get off the line the fastest? By that I mean what's the best way to manipulate the throttle/clutch/brake to get the best launch.
Thanks.
Old Mar 30, 2006 | 12:41 PM
Tik_Tok's Avatar
Tik_Tok
Default RE: Getting off the line!
Practice
It'll be the only real way to figure it out. Find out what RPM's you can rev to and let go of the clutch, and not spin your tires too much.
Old Mar 30, 2006 | 12:55 PM
hawgman's Avatar
hawgman
I ♥ Acer
Pretty much what Tic just said. Practice.
Think of it as using a stair stepper exercise machine. As one foot goes down, the other foot goes up in porportion to the first foot. The key is practicing that method until you find the right ratio of clutch to fuel to achieve maximum launch and minimum tirespin. THEN, once you get comfortable with the feet, start working your way up the RPM range until you find the point that you can launch at the highest RPM using the least amount of clutch possible and getting the maxium traction.
Yup...practice.
Old Mar 30, 2006 | 01:04 PM
Tracedaddy's Avatar
Tracedaddy
K. Then it's more simple than I thought. If it's nothing more than popping the clutch then cool. Thought I'd have to monkey foot the brake somehow. I guess if I'm on a reasonably flat surface I'm golden.
Thanks.
Old Mar 30, 2006 | 01:46 PM
hawgman's Avatar
hawgman
I ♥ Acer
Never anywhere did I say "popping the clutch". All "popping the clutch" is going to get you is tirespin.
jwog666
Dec 27, 2021 08:09 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
