'06 Painted stripes
Old Apr 17, 2006 | 11:23 PM
rennie's Avatar
rennie
Default '06 Painted stripes
Help, I have a '06 Roush that I want to paint "ghost stripes" on that will match the old ('65/'66) Shelby type stripes. By this I mean that the original stripes were wider on the roof and narrow towards the front and rear. Has anyone worked out the proper stripe widths for each separate panel. I have seen a 10" painted stripes over the entire car but they do not look good (to wide) as you approach the vehicle from the front or rear. I have the original diagram for the '65/'66 cars but I'm not sure those measurements will work on the newer Mustang. This is not something you can do over several times, trying to get it correct.
Old Apr 18, 2006 | 12:39 AM
06VistaGT's Avatar
06VistaGT
Default RE: '06 Painted stripes
Take a look here at the 65/66 Shelby stripe dimensions:
Old Apr 18, 2006 | 07:27 AM
nole_trainer's Avatar
nole_trainer
Rennie, I think this might be correct but don't hold me to it. I figured this out some time ago, and the % follow the same 65/66's
Start with whatever width you want at the front bumper/hood, add 13.5% to that to get the top of the hood/start of roof. Then subtract 1.2% to get back of roof. Then substract 2.4% to get trunk. Then substract 1.2% to get bottom of trunk and rear bumper.
Hope that helps and makes sense....
Old Apr 18, 2006 | 11:31 AM
rennie's Avatar
rennie
Thanks for the help. I also have a 1966 fastback (black of course like the '06) with black cherry "ghost stripes" that I'm trying to duplicate the look. I've buried the stripes under the clear coat so if you approach the '66 they are not evident unless the sun is bright. The '66 appears to be a narrower car (leaner) so I was worried that using the original stripe widths would not be wide enough. Thanks again.
Old Apr 18, 2006 | 12:33 PM
nole_trainer
Well there's plenty of pixs on this forum and others to get an idea of what you might want. Post some pixs when you get done!!
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
Mr. D
Sep 16, 2015 11:04 PM
