Wheel Offsets
Old Jun 7, 2006 | 03:46 AM
usnjetmech's Avatar
usnjetmech
Default Wheel Offsets
Just a quick question, I did a search in the forum, and 06GT4RAD says that he posted the wheel offsets, but I have been unable to locate them. I am looking to go 18x8.5 up front and 18x9.5 in the rear. Can somebody please tell me which offsets to order for the wheels.
Also, what do you think of these wheels, and does AR make a good quality wheel?
http://www.americanracing.com/dealer...mega/m198S.jpg
Thanks again for the help!
Old Jun 7, 2006 | 07:39 PM
cortc's Avatar
cortc
Default RE: Wheel Offsets
The stock offset for the 17x8 is 45mm and for the 18x8.5 its 50, for both of the sizes you are looking at with the most a 275 tire you could get by with anything from 40-55 snd the optimal range would be 43-50... I am running 18x8.5 Front +44 & 18x10 Rear +44 and it fits great... As far as tires 255 is best upfront but you could get away with a 275, out back a 285 but you might be able to get a 295 to work...
ORIGINAL: usnjetmech
Old Jun 7, 2006 | 10:45 PM
06GT4RAD's Avatar
06GT4RAD
Sorry man i can not find that post either not sure what happen to it. Here is the info on my wheels I found it in an email i got when i was looking into my Foose Wheels.Cotc has covered it pretty well though it appears.
Front
Bolt Pattern: 5 x 4.50"
ET: +34
Rear
ET: +40
Richard
Old Jun 8, 2006 | 09:48 AM
usnjetmech's Avatar
usnjetmech
Thanks for the help, and appreciate the info!
Old Jul 2, 2006 | 03:21 AM
2k05gt's Avatar
2k05gt
18x9 with a 6.42" backspace (+36mm offset). The lug pattern is 5x4.5 (114.3mm).
Old Jul 2, 2006 | 11:43 AM
drbobvs's Avatar
drbobvs
I have those wheels, in 18x9. 255/45 all the way around. In a 9" wheel as long as your offset is 35mm or less, you'll be fine. Be warned, when you mount those wheels you MUST take off all rotor retaining nuts from your lugs or you WILL get wheel shake!!
[IMG]local://upfiles/16153/8BBDDB66457F417D8747CBFBE01D13F8.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
