Making A Roush Hood Scoop Functional?
Has anyone tried this? Based on the fact that I have vinyl stripes, the Roush scoop looks like the easiest one to add and stripe.
Has anyone tried cutting the hood under the scoop to add a little cooling air flow? I assume the scoop is hollow...have never seen the underside of one.
Also open to other scoop options. I DO NOT want to replace the whole hood. Too much of a pain getting it painted and blended and restriped.
Thanks!
Thanks!
RE: Making A Roush Hood Scoop Functional?
I'm sure you could install the scoop with a hole cut underneath it, but I don't think it would gain you anything....except more dirt and rainwater under your hood.
The underhood temps on our cars drop very well once you get moving.
I'm adding the Saleen S/C next week so I'm just thinking that every degree cooler can only help.
Not trying to get more power, just trying to make it safer and more reliable.
Heat is the enemy of boost![sm=badbadbad.gif]
Thanks!
Thanks!
