Adding Temp Gauge
Old Jul 18, 2006 | 11:46 PM
W1ldcat's Avatar
W1ldcat
Default Adding Temp Gauge
I want to add a temp gauge and was wondering where in the cooling system to put the sending unit (1/8in tap) and how? If you have added one, what did you use?
Thanks,
WC
Old Jul 19, 2006 | 01:52 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Adding Temp Gauge
You have two choices. Either mount it in the water cross over tube on the front of the motor on the passengers side, or, there is a brass plug on the drivers side up under the exhaust header. Either will work.
Old Jul 19, 2006 | 06:48 AM
W1ldcat's Avatar
W1ldcat
Thanks,
Is there a plug in the cross over tube? I'll go look when it gets light. I just don't want it to be a major P.I.T.A. to do. I would like to monitor the temp before I put underdrive pullys on to see if an electric H2O pump is needed. I would rather save my money at this time for other mods higher up on the list. Shocks and springs, long tube headers etc.
I did see where I could monitor it with my X-cal2, but found a digital gauge I like. Besides I like gauges.
WC
Old Jul 19, 2006 | 10:56 AM
hawgman's Avatar
hawgman
I ♥ Acer
You will have to drill and tap if you choose to put the sensor in the water cross over tube. But it is not that big of a deal. You can actually stuff a rag in the cross over tube and drill it with it on the car. Now don't get me wrong, I am not saying that is the correct way to do it, I am just saying it can be done.
Just so happens there is a group buy on the "other" forum for Tokico's and Ebiachs.
jwog666
Dec 27, 2021 08:09 PM
Oct 5, 2015 07:40 AM
mungodrums
Sep 28, 2015 10:54 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
