Fog Light Problem...
Old Aug 3, 2006 | 09:35 PM
ANBAUTO's Avatar
ANBAUTO
Default Fog Light Problem...
I went into work this morning and when a co-worker came into work he asked me whats the things at the bottom of my fog light, I was thinking what the hell is he talking about? So i went outside and looked and I found this! anyone else have this problem? by the way it happened to both lights
Old Aug 3, 2006 | 11:14 PM
DaBoss's Avatar
DaBoss
Default RE: Fog Light Problem...
There is another thread somewhere on this. Mine did the same... no answer on how to fix it yet. I am going to try to get the dealer to repair under warranty. I will let you know how that goes.
Old Aug 3, 2006 | 11:21 PM
bl1nk's Avatar
bl1nk
Wow, thats crazy.. I havent had that problem happen but I have had a ton of little spider cracks all over my fog light lenses... nothing in the headlight lenses though.
Old Aug 3, 2006 | 11:24 PM
CurtX's Avatar
CurtX
Do they still function?
Old Aug 3, 2006 | 11:46 PM
astroGT's Avatar
astroGT
Did you change out your bulbs at one point?
Old Aug 4, 2006 | 12:07 AM
BeeStang's Avatar
BeeStang
It happened to both mine after putting in aftermarket bulbs. The shrouds came loose because of the higher wattage/heat generated by the aftermarket bulb. I put the stock bulbs back in, and took it to the dealer and they replaced both fog light assemblies under warranty. Also, the new lights look a lot better since they do not have the foggy or dull chrome haze on the reflector like the originals. The glue that holds the shrouds in melted and both fell out, not to mention, the chrome reflector also melted a little. DO NOT upgrade the bulbs or this will happen, eventually.
Old Aug 4, 2006 | 02:44 AM
DaBoss's Avatar
DaBoss
Yea, I changed out my stock for the higher wattage Nokya's. I will definately put the stock bulbs back in before I take it back to the dealer. The lights work fine, but it looks like crap with the deflector sitting in the casing like that.
Old Aug 4, 2006 | 03:00 AM
ANBAUTO's Avatar
ANBAUTO
Yea mine still work as well, But i changed mine out for yellow bulbs same wattage though.
Old Aug 5, 2006 | 12:26 PM
frdfrst's Avatar
frdfrst
i had the same problem.put stock bulbs back,took it in.replaced under warrenty.put some adhesive around the the metal ring that fell off and it cured it.make sure glue is high heat.[sm=badbadbad.gif][sm=goodidea.gif]
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
