Water Temp Sending Unit
Old Aug 5, 2006 | 12:35 AM
rfelger's Avatar
rfelger
Default Water Temp Sending Unit
Where is a good spot to hook up to for water temp?
Old Aug 5, 2006 | 01:24 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Water Temp Sending Unit
Drill a hole in the water crossover on the passengers side. Perfect spot for it.
Old Aug 5, 2006 | 01:33 AM
rfelger's Avatar
rfelger
Sounds good thanks!!
Old Aug 5, 2006 | 01:35 AM
rfelger's Avatar
rfelger
Any ideqas on Oil Press & Temp locations??
Old Aug 5, 2006 | 02:56 AM
281GT's Avatar
281GT
Here you can see where I installed mine. Just remove the plug from the crossover, drill and tap. I used a file to file the two sides of the plug flat so I could get a wrench on it. That's all there is to it!
[IMG]local://upfiles/13562/4141543EAB614ABB8170987EF141C71D.jpg[/IMG]
Old Aug 5, 2006 | 03:05 AM
rfelger's Avatar
rfelger
cool, thanks
Old Aug 5, 2006 | 10:03 AM
hawgman's Avatar
hawgman
I ♥ Acer
ORIGINAL: 281GT
Absolutely incorrect place to put your tempature sensor for two reasons.
First, it is on the wrong side of the water flow. You are measuring the water tempature out of the radiator there. You need to do it on the other side where water exits the engine.
Second, that is the air bleeder valve for your cooling system. That "plug" as you call it is meant to be removed so that you can bleed the air out of your cooling system if you ever have to drain it for any reason. Otherwise you will get steam pockets in the system.
Old Aug 5, 2006 | 02:03 PM
rfelger's Avatar
rfelger
Wow,glad you noticed that. I thought that looked alittle funny
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
