FRONT Drilled Brake Rotors
I know this will be bumped to another location, but is anyone running aftermarket cross drilled brake rotors that area bolt on using the stock caliper...front brakes only...? I would like to add some visual behind the wheel appeal....forgot to add...for an '07 GT
RE: FRONT Drilled Brake Rotors
Try these...I don't think anything has changed on the '07 brakes/rotors.
http://www.brenspeed.com/mustang_2005/brakes.html
ORIGINAL: scramblr
Richard
Hawks kinda the going thing for Pads right now, but I'm not one to follow a crowd just to follow it. What pads are you using or recommend? I have EBCs on my wife's car (Stratus R/T). Although they work great and are quiet, they are very dusty as well.
ORIGINAL: nonstopred
if you look on ebay theres a bunch but beware I heard that they crack under the heat of braking soooo Dont get em
i havent experienced it, someone else mentioned that to me. also the drilled and slotted rotors with the small little edges from the cut holes, shave the pads easier and make em wear quicker
maestro1024
09-21-2015 02:40 PM
09-08-2015 11:50 AM
