Big problem?
Old Sep 22, 2006 | 09:39 PM
Thetics's Avatar
Thetics
Default Big problem?
I just noticed that (cant remember exactly) about 3, if not all of my callipers have deep grooved scratches on them, like the inside of the rims are touching as i drive. Anyone know why this is? or experience anything similar? Im all stock. I DID just have jiffy lube rotate my tires.. they rotated them front to back (not across? i dunno if this is of any importance or not.) I saw the guy rotating the tires, i was watching, everything seemed okay... any help would be hot. Ive got a date with the dealer monday, should i tell em theyve been rotated?
Old Sep 22, 2006 | 09:50 PM
TPony's Avatar
TPony
Default RE: Big problem?
Are your calipers painted? If so, are do they look scratched after you painted them? Reason I ask is because when I removed the rear wheels to paint my stock caliper, I noticed some deep grooves on them...as if someone used a wide file and filed a portion off. Both rear ones looked the same. However, I painted the calipers and they still are painted, so I figured it was someting done at the factory or that's just the way they were. Have you heard any grinding? Although it would be strange that the rims would be touching the calipers without any major damage to rims and calipers. [sm=interesting.gif]
Old Sep 22, 2006 | 09:55 PM
Thetics's Avatar
Thetics
not painted.. but in ur case, obviously the damage was done by the time u painted, so it was already filed down enough for clearance thus, not touching after painting.
Old Sep 22, 2006 | 09:59 PM
TPony's Avatar
TPony
Well, unless someone else come up with a possible scenario, recommend you tell the dealer about it. The fact that the tires were rotated should not be an issue IMO. keep us posted.
jma2
Jul 10, 2023 01:00 AM
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
MasterLanMan
Sep 13, 2015 08:21 PM
DoctorScary
Sep 9, 2015 07:53 AM
