problem solved, thanks guys!
Old Oct 25, 2006 | 09:23 PM
blackout's Avatar
blackout
Default problem solved, thanks guys!
How do I get a wire through the gromet by the foot pedal to the engine bay? I've done it one time with my amp power cord, but I have sold my system off and cannot get any wire through there anymore. Any help would be greatly appreciated, i'm trying to finish the install on my shift light.
-Jeff
Old Oct 25, 2006 | 10:18 PM
blackout's Avatar
blackout
Default RE: PLEASE HELP! Gromet by Clutch Pedal to the Engine Bay
bumpity bump bump bump
Old Oct 25, 2006 | 10:37 PM
Riggs007's Avatar
Riggs007
I used a flat head screw driver, pulled the grommet into the car, pushed the wire through and replaced
Old Oct 25, 2006 | 10:48 PM
howarmat's Avatar
howarmat
s197 Junkie
That is basically what I did also. I need to find a way to make the opening a little bigger now to fit another wire through. Might have to do a little cutting.
Old Oct 25, 2006 | 10:53 PM
blackout's Avatar
blackout
Yes, but where did you push it through to get it out into the engine bay. It never goes to the right place when i'm doing it...
Old Oct 25, 2006 | 11:06 PM
howarmat's Avatar
howarmat
s197 Junkie
Yep...it took a couple 10 times maybe. You will have to reach down and pull it through or use a hanger even to help pull it. If you get it through at all take it, and route it the best you can. I had to shove 7-9 feet of thin wire in there for my navigation.
Old Oct 26, 2006 | 12:32 AM
drbobvs's Avatar
drbobvs
Man there's like a 2" by 2" rubberized pad above and to the left of the brake pedal. You could put a PVC pipe through! I've run everything through there. It's usually covered by a piece of foam on the interior side.
1st 4 eyed fox
Aug 15, 2015 02:16 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
stanngg
Aug 12, 2015 03:43 PM
philster0306
Aug 10, 2015 11:33 AM
