Nitrous -- Pro/ Cons !?!
Old Nov 28, 2006 | 03:52 PM
Caution's Avatar
Caution
Default Nitrous -- Pro/ Cons !?!
Can someone tell me how hard Nitrous is on the engine... I was thinking something smaller like a 50 shot maybe but don't know to much about running nitrous. What mods are good to have before running it so on and so forth? I'm curious to know how damaging it can be. You know what they say --
Nitrous is like a hot chic with an STD - We all wanna hit it but are scared of the consequences! [sm=gears.gif]
Old Nov 28, 2006 | 04:14 PM
raylandm's Avatar
raylandm
Default RE: Nitrous -- Pro/ Cons !?!
hehehee hot chick with an STD...never heard that one before. Im dying to find out also.
Old Nov 28, 2006 | 06:36 PM
androdz's Avatar
androdz
I ♥ Acer
with a 50 shot it wouldn't be more than a tickle on the engine. I would recommend a 75 shot if you wanna be safe anything over you need a tune. I am currently running a 150 shot, no problems yet. Of course it is all in the tune and knowing well your transmission. I have missed shifts 2x and nothing has yet to happen, I do know that missing shifts on nitrious or excessive wheel spin is what specially get motors blown.
Att. Andrew
Old Nov 28, 2006 | 06:49 PM
Caution's Avatar
Caution
Androdz- 150 shot! DAM! I guess you have no problem bangin the chic with the STD eh!?! Thanks for the information!
Old Nov 28, 2006 | 06:56 PM
Fast Toys's Avatar
Fast Toys
Banned
Nitrous is far and away the best bang for the buck when it comes to performance increases. Unfortunately, when something goes wrong using Nitrous, the results are usually quite severe. There are things you can do to mimize potential problems:
1. fuel pressure cut off switch
2. RPM window switch
3. WOT switch
4. Bottle warmer
5. Running a smaller shot
The biggest problem is that more power is only a jet away and people get greedy!
Nitrous containers also cannot be in the vehicle on a public street in some areas as it is a compressed gas (requires special transportation).
One of the vendors we deal with has a new kit that uses CO2 in a nitrous like delivery system but instead of being injected into the motor, it cools the intake charge. Every 10 F drop in intake temp on NA is 1 % increase in power and 2 % on forced induction applications. Not nearly the same power gain as NOS but very low risk and CO2 is cheap and safe.
Old Nov 28, 2006 | 06:59 PM
Mach's Avatar
Mach
hmmm sounds like its not too bad of a deal if you keep it within reason, I may start looking at the juice
Old Nov 28, 2006 | 07:01 PM
moosestang's Avatar
moosestang
Maybe if you are power shifting! If you lift your foot when you shift then how can nitrous cause a problem? All the kits i've seen spray at WOT only.
ORIGINAL: androdz
with a 50 shot it wouldn't be more than a tickle on the engine. I would recommend a 75 shot if you wanna be safe anything over you need a tune. I am currently running a 150 shot, no problems yet. Of course it is all in the tune and knowing well your transmission. I have missed shifts 2x and nothing has yet to happen, I do know that missing shifts on nitrious is what specially get motors blown up or excessive wheel spin.
Att. Andrew
Old Nov 28, 2006 | 07:04 PM
Caution's Avatar
Caution
Fast Toys- Thanks! So what is a WOT switch? What is the RPM window switch? What does the fuel pressure cut off switch do with the NOS? The Co2 does sound a ton safer though.
Old Nov 28, 2006 | 07:05 PM
Caution's Avatar
Caution
Ummmm whats a WOT? Sorry but not familiar with NOS at all? [:@]
Old Nov 28, 2006 | 07:07 PM
moosestang's Avatar
moosestang
ORIGINAL: Fast Toys
My father has a propane tank mounted on his motorhome. he don't have no stinking permits!
