05 Throttle Body issues-throwing codes
Old Dec 5, 2006 | 10:55 AM
RocDoc's Avatar
RocDoc
Default 05 Throttle Body issues-throwing codes
Anybody with an 05 Mustang GT having problems with the throttle body throwing codes? Need some help or advice.
I have a tech working on it now for the second day. No help so far. Any ideas?
Old Dec 5, 2006 | 10:58 AM
CrazyAl's Avatar
CrazyAl
Default RE: 05 Throttle Body issues-throwing codes
Yes, get rid of the throttle body. With your blower you don't need a bigger TB anyways. If you want more power get a different pulley.
They are notorious for this. Do a forum search for "throttle body" and you will get to read all the past horror stories about them. Thrown codes and tuning hassles are par for the course.
Old Dec 5, 2006 | 11:14 AM
MusiccityGT's Avatar
MusiccityGT
I don't see an aftermarket T/B in your mod list, but if that is the case, I agree with Al 110%. If it is OEM, then you probably have a bad T/P switch or Throttle control motor. Take the intake off and have someone cycle the key. You should see the butterflies snap open and shut as the car does it's self test.
Old Dec 5, 2006 | 01:51 PM
Caution's Avatar
Caution
+1 with Crazyal! I was going to get one myself and did a search first and saw that they suck... well are giving problems to mosy anyway... I ended up getting a TB spacer for my stock TB and that was fine. Good luck on the car.
Old Dec 8, 2006 | 03:06 AM
Herknav's Avatar
Herknav
$73 for a TPS replacement and 5 minutes to change it out.
There is a TSB on this I believe... so if you are (mostly) stock, you should have the dealer fix it...
Old Dec 8, 2006 | 12:03 PM
shaners90lxhatch's Avatar
shaners90lxhatch
You may want to base your repair efforts according to the codes your vehicle sets. Often the trained techs are confused on exactly what the fault code indicates - likely the information the public is privy to won't provide the detail necessary to properly diagnose the issue. If you can get the codes it is setting, I can tell you what you need to do.
Old Dec 8, 2006 | 12:35 PM
Sleeper05's Avatar
Sleeper05
tb gave me 11rwhp/13rwtq...but in all honesty, the idle problems and the occasional failsafe mode aren't worth the hassle
Jb145700
Aug 21, 2022 06:37 AM
JDWalton
Sep 24, 2015 08:47 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
pimp2303
Sep 17, 2015 08:45 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
