bad wheel hop>
bad wheel hop>
my car wheel hops terribly. i saw something that connects to the transmission that looks like it would make it more solid. and what bout sub frame connectors. upper and lower control arms. will that stuff eliminate the wheel hop.
RE: bad wheel hop>
The Che A-Arm Brace with Torque Limiters will limit the "twist" of the transmisison...but will not do anything to fix wheel hop. LCAs and a UCA will eliminate it. If you're lowered or thinking about lowering, get LCA relocation brackets as well along with a panhard bar. If lowered, you can do either adjustable LCAs or adjustable UCA. This is important as you will need to set your pinion angle. If you want to keep noise down, make sure you get the ones with poly bushings vs the spherical ends.
Hell...I just looked at your sig and what you've done to your '99...doesn't sound like I'm telling you anything you don't already know.[8D]
