Seam Sealers, Sealing, and Spots?
No alliteration intended. (Puns always intended - why don't more people intend their puns, and instead excuse them? It's one of the best parts of language) ANYWAYS ...
So I want to buy some seam sealer to seal some unsealed seams on the undercarriage to prevent dirt/salt/etc from getting into the seams to prevent rusting. I hear 3M makes some of the best seam sealers out there, but which one of 3M's sealers should I use?:
http://products3.3m.com/catalog/us/en001/.../
Also, where should I seal these seams? I mean, should I seal all seams that I find? I'm worried about sealing anything that might be a "drain" for moisture or water, or whatever. Can I spray Krylon zinc-rich primer & enamel over sealant?
Any thoughts appreciated.
RE: Seam Sealers, Sealing, and Spots?
I wouldn't seal anything. You run more of a risk of trapping moisture; Air in and around the panels is best. They are coated for protection that will last longer than you will likely own the car. Water, rain is not a problem. Salt is the one killer but you can power rinse the underbody if you drive in such winter conditions;
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
