GT500 hood...what's it made of???
Hi guys...
I am going to do a bumper swap on my GT for the GT500 bumper. I want to go with the GT500 hood too, but I am thinking of deleting the vents on the top.
Can anyone tell me what material the hood is made of? Is it fiberglass or metal? If it's metal...is it aluminum??
Thanks a lot
Thanks a lot
RE: GT500 hood...what's it made of???
Why would you want to buy a GT500 hood and then get rid of its vents?
Just get a hood without vents... like the one you already have!
The GT500 hood should be aluminum, but the manual doesn't say. They call it a "power dome hood" and the vents are "functional heat extractors".
The GT500 hood is taller in the center, and the front near the grille is arched, giving the grille area a bigger, more agressive look.
The vents look totally silly to me, and cost an additional $600.
Not impossible with a TIG welder, some aluminum sheet, and patience and heat clay to prevent warping and a bunch of bodywork. Cost /labor wise, you will not come out ahead.
The aftermarket is already working on nicer vents. I think shelby themselves along with ford has something already.
600 for the vents??? Someone is ripping you off bro. I can get those vents for much much less then that. I can probably set you up with the entire hood for a little more then 600. FORD PARTS. Not re-po stuff.
ORIGINAL: PERTANO
So you can get stock parts? What can you get the front bumper, headlights, grilles, and fog lights for?
