Ground point under dash
Old Jan 22, 2007 | 02:15 PM
woody77's Avatar
woody77
Default Ground point under dash
I am installing a Roush front fascia and fog lights. The fog light switch needs a ground point, the instructions say use ground point under the dash. Does anyone know where there is a factory ground point under the dash on the drivers side or will I have to drill a hole and make a new ground?
Thank you for the help,
David
Old Jan 22, 2007 | 02:55 PM
Archion's Avatar
Archion
Default RE: Ground point under dash
any bolt or nut on the metal frame of the dash will work.
Old Jan 22, 2007 | 03:48 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
^^^^^^what he said.
Old Nov 6, 2023 | 10:19 AM
Jim Machamer's Avatar
Jim Machamer
Default Ground problem?
I have a 1965 6 cyl. Coupe had underdash wireing done by classic auto shop, I replaced under hood called headlight harness basically main wires, everything working fine all summer, turned on heater motor thought blown fuse blower motor shut off lost idiot lights no turn signals no gauges, curtesy lights work radio works glovebox light works headlights work no wipers what should I look for. Thanks
1st 4 eyed fox
Aug 15, 2015 02:16 AM
Rusten
Aug 7, 2010 05:17 PM
onetrickpony
Aug 25, 2006 08:06 PM
gtstang2000
Apr 25, 2006 11:11 AM
5.0shelby
Dec 20, 2005 02:55 PM
