drive by wire
Old Jan 27, 2007 | 01:12 PM
  #31
panzermk2's Avatar
panzermk2
Default RE: drive by wire
try sync shifting sometime
Old Jan 27, 2007 | 05:17 PM
  #32
HypromanGT's Avatar
HypromanGT
ORIGINAL: panzermk2
What's "sync shifting"...?
Old Jan 27, 2007 | 05:55 PM
  #33
Black GT's Avatar
Black GT
ORIGINAL: HypromanGT
ORIGINAL: panzermk2
I think that would be shifting without using the clutch. Shifting slowly at just the right time and RPMs when everything is in sync and you don't need the clutch. I used to do it on a F-150 truck I owned.
Old Jan 27, 2007 | 07:09 PM
  #34
shockme76's Avatar
shockme76
I know there have been a select few of people that have reported their stang accelerate on it's own and given that the throttle on our cars is now controlled by DBW could this be a possible cause to those claims? I know those who have reported it have pretty much been called crazy but if you really think about it, it's not far fetched at all given that it is controlled by a computer. Any thoughts?
Old Jan 27, 2007 | 07:44 PM
  #35
my77stang's Avatar
my77stang
i'd like to know if by using higher octane these computers will "learn" they can advance the spark a little more without causing problems and actually retune themselves to be better than by default?
in theory its possible.... any thoughts?
Old Jan 27, 2007 | 09:49 PM
  #36
scrming's Avatar
scrming
ORIGINAL: my77stang
Yes, the computer will try to add timing ... if you monitor the knock sensors you can see they not only take away timing but they will also add it as well...
Old Jan 28, 2007 | 11:52 AM
  #37
my77stang's Avatar
my77stang
wow thats the first good news i've heard from these damn puters
Old Jan 28, 2007 | 05:20 PM
  #38
panzermk2's Avatar
panzermk2
ORIGINAL: panzermk2
Pretty much although you don't have to do it slow. You reach your shift piont pull the shifter out of gear and match the engine revs to the speed of the trany. It will pop rite in and once you get good you can shift just as fast and smooth as if you were using the clutch. I brought this up since thatsone of thingsthe engine management system is doing "for us" to enablesmoother and bettershifting
Old Jan 28, 2007 | 05:22 PM
  #39
panzermk2's Avatar
panzermk2
ORIGINAL: scrming
ORIGINAL: my77stang
Will they add it enough to be worth the extra cost of 91 octane?
Old Jan 28, 2007 | 06:44 PM
  #40
scrming's Avatar
scrming
ORIGINAL: panzermk2
ORIGINAL: scrming
ORIGINAL: my77stang
One of the magazines tested it... showed a 5RWHP gain... if it's worth it or not is up to you... LOL!
