CEL FROM CAI
Old Jan 29, 2007 | 11:12 PM
JAYS06SILVERGT's Avatar
JAYS06SILVERGT
Default CEL FROM CAI
OK HERES THE DEAL, I INSTALLED A BBK CAI. I GOT IT FROM RPM OUTLET WHICH IN THE AD STATES THIS IS ON OF THE ONLY SYSTEMS THAT DOES NOT NEED AN AFTER MARKET TUNER. SO AFTER ABOUT 300-400 MILES I GET A CEL AND HAVE IT CHECKED, ITS RUNNIN LEAN. I HAVE A CALL INTO BBK AND RPM? DOES ANYONE HAVE ANY SUGGESTIONS. I DID DO THE QUICK FIX WHICH WAS TO REMOVE THE NEGATIVE BATTERY CABLE FOR A FEW MINUTES THAN RECONNECTED. THAT ACTUALLY CLEARED IT FOR NOW.
Old Jan 29, 2007 | 11:21 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: CEL FROM CAI
2 suggestions
1) Dont buy from RPMOutlet as the problems with them have been well documented.
2) Buy a CAI with tuner since your gains will be 25-28 hp
B amachips, Brenspeed and EVO are recomended.
As for your current problem. Take it off for now.
Old Jan 29, 2007 | 11:24 PM
WhiteStallion06's Avatar
WhiteStallion06
If you wanta cai with no tune required go with a k and n or for best results use the granatelli ... but if you want the full effect get a tune
Old Jan 29, 2007 | 11:28 PM
JAYS06SILVERGT
I would have to agree on RPM Outlet but thats for another thread. I really like the BBK CAI so what would be a good compatible tunner?
CrazyAl's Avatar
CrazyAl
ORIGINAL: howarmat
2 suggestions
2) Buy a CAI with tuner since you gains with be 25-28 hp
+1 Excellent advice!
Old Jan 30, 2007 | 12:34 AM
newfer23's Avatar
newfer23
If you want to keep the intake I would go with the SCT Xcalibrator 2 tuner. There's that and the Diablosport tuner but in my looking around I've found that most people prefer the SCT. And they're both about the same price. If you're gonna be a bit before you buy the tuner take the intake off. No point in potentially harming your engine. Good luck!
Old Jan 30, 2007 | 12:46 AM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: CrazyAl
ORIGINAL: howarmat
2 suggestions
+2
Richard
Old Jan 30, 2007 | 12:55 AM
JAYS06SILVERGT
Thanks, I have been checking both those out. Hypertech came out with a new tuner that is pre-programmed with 10 diffrent CAI. So I am going to check that one aswell. I am just waiting to see what BBK has to say?
Old Jan 30, 2007 | 01:03 AM
howarmat's Avatar
howarmat
s197 Junkie
The "10 different cais" would just be the "canned" tune for that intake. This is NOT what you get with the actual tuners I mentioned above. They will ask you about other mods you have on your car and develop a custom tune just for you. I tried the C&L with canned Predator tune. Really did not notice that much of a difference. Order a tune from B amachips and the experience is not even close. Its a whole different car now. The same can be said about Brenspeed. This difference can not be stressed enough in my opinion.
Jb145700
Aug 21, 2022 06:37 AM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
junior04
Sep 28, 2015 10:53 AM
firecoyote
Sep 27, 2015 02:37 PM
