What could cause this noise?
Old Mar 8, 2007 | 01:32 PM
richmod's Avatar
richmod
Default What could cause this noise?
[hr]
06 GT, auto, no mods (yet).
Looking for all possibilities: Hum/Moan type noise from rear end, consant pitch and volume from about 40 mph to 65. At 65 mph, it increases in volume (louder) by about 50% - again same noise, same pitch, just louder. Fades off at about 68-70 mph. I don't hear it at all above 75 mph. No change on throttle position (accel, decel, cruise). No change in gear position (including neutral).
Key point: at 65 mph, I noticed if I swerve in one direction, it goes away (or greatly reduces), if I swerve in the other direction, it gets louder. that made me think it's a tire issue, but a recent tire rotation did not cahnge the noise.
Other than tires, could it be:
-a differentail bearing? If the bearing is shimmed too tight, would it make this type of noise?
- clutch pack? I don't have any noise on low speed turning.
- other?
Rather than go into detail about the service history on my car, I'd like to just get some ideas based on the info provided. TIA.[/align]
Old Mar 8, 2007 | 02:01 PM
schmitty's Avatar
schmitty
Default RE: What could cause this noise?
i have the same noise, one of my tech's says its probably outer wheel bearing, the noise goes away when you take the load off. not sureif it is a problem???
Old Mar 8, 2007 | 02:14 PM
SOHCman's Avatar
SOHCman
Bearing, noise, problem, warranty.
SOHC
Old Mar 8, 2007 | 02:33 PM
Jays Mustang's Avatar
Jays Mustang
If you haven't done any mods to the rear, whatever it is, should be covered under warrenty.
Old Mar 8, 2007 | 04:06 PM
2cokeman's Avatar
2cokeman
I have a sort of high pitch noise in 5th at a contant speed, told it is normal? Any one else have that?
Old Mar 8, 2007 | 09:52 PM
richmod's Avatar
richmod
So, on the way home fromwork tonight, I tried serving again. Swerve right - noise diminishes. Swerve left - louder. Then I just VERY slightly swerved right and left, I'm talking as little as possible - same result. So now I'm thinking it's gotta be a FRONT tire or bearing, 'cause the load on the rear wheels isn't changing that much to cause such a difference in sound. So now my question is - does anyone have a diagram or picture of the front suspension? This may be a dumb question, but where exactly is the front wheel bearing? I searched fordparts.com and all it shows is aHUB AND BEARING. Is that it?
Old Mar 8, 2007 | 10:03 PM
moosestang's Avatar
moosestang
ORIGINAL: richmod
That's it.
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
